FREEBALL
- york pa usa
I have a question on heat mats. I copied this excerpt from agritape which has me puzzled.
"An Agritape system consists of a control unit to regulate soil temperature, the Agritape Heat Mat, and a grounded screen. The screen serves to protect the tape from physical damage, to safely ground the current if the tape is penetrated, and to draw off static electrons that collect on the surface of the tape. (The tape acts as a capacitor when it is in operation.) The flow of static electricity can trip GFCI outlets if the system is not properly grounded. The screen also holds the tape in position on the bench".
Why would it matter if the system is not properly grounded, The system is properly grounded by the way, but why would static electrons trip a GFI. They placed screws into the metal screen and ran to the control box as stated to do, but all this does if gives any leakage current an alternative path which will trip the GFI. So what are they talking about stray electrons, it seems the heat mats are shorting out to the screen which is grounded and current is leaking to ground thus tripping the GFI. In the paperwork with the mat it says that if the grounding does not work to simply isolate the ground wire to a separate form of grounding instead of the ground that comes connected to the control box.
They started watering the plants on Friday and Saturday the gfis for the mats began tripping. I believe they need better heat mats.
any ideas.
any ideas.
