We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
I have a AHU no strips min 1 amp max 15. I have it on 15 amp fuses. I got a heat pump min 20 amps max 35. I have both AHU and heat pump on on 30 amp breaker. Is this a code violation to have both units on one breaker
I think we need a description and diagram of how they are wired. Like, does one feed the other and/or if there's any additional overcurrent device for the heat-pump. Not enough info otherwise.
