Heat Pump Breaker Size
Newfiepet
New User
Newfoundland
Retired
Looking for confirmation on Size of Breaker and Wire for this Heat Pump. Specs on sticker attached to unit are as follows:
Senville
Outdoor Model SENA -33HF-OQ
Power Source. 208/230V-60 Hz, 1Ph
Design Pressure. Hi 550 PSIG/3.79MPa
Refrigerant R410A/102.29oz (2.9 kg)
The Rated Input Current of the Power Conversion Equipment 27.5A
Minimum Circuit Ampacity 36.0A
Max Fuse 40.0A
Outdoor Unit Resistance Class IPX4
I believe I will need a 40 amp Breaker and #8AWG Wire but need some confirmation. Would the #8 wire need to be 8/2 or 8/3?
Thanks for your advice!
From what profession are you retired? We are not allowed to assist a person who is not an electrician to perform their own electrical installation work. Pleass update your profile accordingly.
