john14
- San Jose, CA
Hi guys,
I'm having 4 roof top heat pumps installed in a building and I have grounding question. AC contractor wants to run 3-#8 (35A 3phase), 1-#10 gnd, 1-#12 hot, 1-#12 Neutral (per unit). Can the service outlet attached to side of AC disconnect switch be grounded to the #10 ground that is there for the heat pump? Heat pump and service outlet circuits run in same conduit. I found lots of posts on service outlets but I don't think any mention the ground.
