wayne123
- North Carolina
I am installing the electrical supply to heat pump furnaces in a new house i am wiring.There is a 4 ton furnace unit under the house that has two 60 amp breakers instaleed in it.The max breaker size on the furnace is 90 amp @ 240 volts.Will it be ok to just install a pull out 100 amp disconnect beside the unit for disconnection or should i install a 100 amp panel with a 100 amp 2 pole breaker?
