General question here. The sizes of heat pumps are characterized by the tonnage, correct? And if so, what amperage rating would you use for a 4 ton HP?
How low/high do the tonnage ratings go and how do you determine the circuit conductor size if you don't know how big the HP will be if only the furnace is installed? Thanks!
