I'm installing a new 480/277v heat trace panel in a plant. I will be pulling off the mcc with 480v delta 350amp breaker. If I remember correctly I will need a 480v delta to 480v wye transformer for my neutral since all heat trace will be 277v. Since the voltage is the same though the transformer do I still need a main breaker at 350a on the panel?
