Ambient44
- Oak Lawn, IL
We recently were bought onto a Chemical plant to bid on installing heat trace cable, the plant has a lot of existing 120 & 277V heat trace already installed on chemical lines, mostly caustic 4"to 6" lines that need to be 80-90F maintained. (Caustic hardens at 50F). They are re-doing a section of pipe for the caustic tanks and asked us to quote re-installing the heat trace once the pipework is done. Upon investigation of the existing installation, it was determined the previous contractor ran a non-heat trace 2-conductor cable along the existing pipe that was heat traced to extend the 120v circuit to another area of the pipe that needed a new heat trace line installed.
I have never seen this installation method for heat trace and was wondering if anyone know if this was in violation of the code?
It seems it is a lot more reasonable then running PVC coated GRC conduit to a splice box. (Caustic is highly corrosive).
Thank you for your input
