ibew501ed
- danbury ct/work in white plains ny
What code section covers heat trace cables installed on water lines? It appears to be 424.1 My question is should heat trace be installed with gfci or gfpe?
Conditionally, GFP... see 427.22What code section covers heat trace cables installed on water lines? It appears to be 424.1 My question is should heat trace be installed with gfci or gfpe?
I am... but open to correction as, even though I've installed plenty, this is the first time I've ever looked it up in the Code :roll::roll::roll:Smart are you saying heat trace is 427?
