Heat trace on plumbing vent pipe
cce
Alaska
Hello,
I live in northern Alaska and sometimes during extreme cold spells the vent pipe for the plumbing in homes will free shut. Usually all the needs to be done is to crawl up on the roof and dump boiling water back down the vent to thaw it out. I have a owner that has just built a large cathedral style home with steep pitched roofs. He wants to be able to heat trace the vent so he will not have to try and crawl up on the roof if it freezes shut. Does anybody have any ideas? Could you drill a hole in the vent pipe inside the attic and insert an capillary tube type heat probe up the pipe? EPD Breaker of course, but does anybody have any other ideas or solutions? You would need to have heat trace in both the attic portion and also the portion that is above the roof line I would think.
Thanks for the help
Re: Heat trace on plumbing vent pipe
I'm not a plumber, but I believe that the water level in a vent pipe goes nowhere near the roof line level. If you can experiment with the water level in that pipe, then only heat trace from there down. Probably the circumfrencial type of wire wrap would be better, rather than penetrating the pipe.
I would try electric heat trace (self limiting type)on the outside surface of the vent pipe, and then cover with pipe insulation in the attic and outside area. Ref NEC Art 427
http://www.nelsonheaters.com/Products/Heaters/Cables/Cables.htm
edit: How about just shoving a suitable length of heat trace cable down the top of the vent or install a "tee" just above the roof and use it for the heat trace entrance fitting?
Len
[ March 07, 2003, 05:54 PM: Message edited by: Len_B ]
It is not water that makes the pipe freeze. Its frost build up inside the pipe. Also, If I were to heat trace I would have to wrap around the pipe inside the attic and then try to transition through the roof next to the pipe to wrap around the portion that is on the outside that sticks above the roof. That transition where it goes through the roof is what has me puzzled. Also, in this instance the pipe actually is not in an attic at all. It goes up through the roof in a 6 inch wall. So There would never be any access to it.
In Anchorage and the Valley I see plumbers oversize the pipe about 3 feet before it exits the roof. They also make sure it is insulated to the point of where it exits the roof.
With a cathedral ceiling the problem shouldn't be as bad as the vent passing thur a large cold attic.
Certified Plumbing vent - ArcticVent
Hazloc does not permit heating cables within plumbing vents
There is a CSA c-us certified product being installed and specified throughout Canadian arctic.
My company developed it more thad 3 years ago and there is currently one at the Fairbanks Alaska CCHRC undergoing research.
The product is completely successful and can be seen at www.heatline.com
Kind regards
Lorne
