my 13200 / 7620 KV Y transformer emits abnormal heat even it is underloaded at 30% loading can anybody help me? if i cannot solve this i might be terminated!!!
Help me out here. What is a "bowsered"?when last bowsered, etc?
"abnormal" definitely needs to be quantified.
I've seen a few cases of "abnormal" heat with properly loaded transformers that can be attributed to their not being level and having an oil flow problem.
In one case there was blockage in the oil path to some of the "fins"
Thats what I am guessing too, common problem to have restricted flow in the fins, should look like this.
Does the image really show restricted flow?
85 Deg F doesn't seem very hot - I'm hotter than that.
The circulation depends on a temperature difference between the top and bottom.Just because a surface is too hot to touch doesn't necessarily mean the device is overheated.
db
I had similar concerns on a transformer install I did... it was just too hot to touch. I read 286?F is some places. Contacted the manufacturer, and they said that's normal.
cf
I agree. The manufacturer should be able to provide a test sheet with losses and designed winding and oil temperature rises.I had similar concerns on a transformer install I did... it was just too hot to touch. I read 286?F is some places. Contacted the manufacturer, and they said that's normal.
I think that should be the starting point.
Any chance you are dealing with a major harmonics issue?my 13200 / 7620 KV Y transformer emits abnormal heat even it is underloaded at 30% loading can anybody help me?
