Fordean
- New Jersey
- Electrical Contractor
I agree I probably should have to just eliminate this question. But I already ran it. 15 ampwho knows what it means. there is so little difference in nhe cost of running a 20 A circuit versus a 15 A circuit that I would be inclined to just run a 20 A circuit.
1800 Watts seems like a lot for a heated toilet seat to me. It does not take a lot of heat to warm up something that small.
Part of the heat may be used to warm the bidet water.I agree I probably should have to just eliminate this question. But I already ran it. 15 amp
The attached file say system circuit size. 120v 15amp. I agree a fully loaded 1800 watt seat probably burn your ass.
Did you view attachment. Just curious if I upload it correct and is viewable
It doesPart of the heat may be used to warm the bidet water.
Can you imagine a toilet seat WITHOUT a thermostat? Yes, sitting on a cold toilet seat can be a "wake up call" on a cold morning, but NOTHING like burning your bum (or worse)!I assume its controlled by a thermostat, and so 1800 watts would not be pulled for long.
So it could be plugged into a 15 amp receptacle on a 15 amp circuit. But that would have to be the only receptacle on that circuit.
I agree 1800 watts seems like a lot - I'm a little skeptical it will actually pull that much.
FEATURES
- Hybrid heater provides continuously heated water for consistent comfort
- Self-cleaning function uses UV light to automatically clean the wand surfaces
- Sleek, handheld remote control with two programmable user presets
- LED lighting illuminates the bowl to serve as a nightlight
- Heated seat with adjustable temperature settings
- Front and rear wash modes provide warm water for cleansing
- Adjustable water temperature and water pressure
- Quiet-Close™ elongated lid and seat prevents slamming
- Quick-Release™ functionality allows seat to be removed easily from toilet for convenient cleaning
- Toilet seats are not returnable to Kohler Co. if opened or outside of original packaging
We're concluding it's not.Wonder if it is considered a continues load ?
Bad attempt at humorWonder if it is considered a continues load ?
It depends what you had last night. Some days I get a knock on the door "dad come out, you've been in there for three hours"Bad attempt at humor
No, that was my point when I said it probably has a thermostat. It's not a continuous load because its turned on and off by a thermostat.Wonder if it is considered a continues load ?
LOL... went right over my head...Bad attempt at humor
Or under your... oh, never mind.LOL... went right over my head...
