Hello,
Im calculating a house that would be moved to a job site for housing.
There is going to be 4 bedrooms, each having there own bathroom, water heater
& heating / AC unit. The water heaters are 1650 watt 120 volt each and
the heating unit is 3500 Watts 240 Volt. The kitchen, living area
would have two of these heaters and one 1650 watt water heater.
If they are able to establish the house as a single family dwelling,
can I use th optional calculation for single family dwelling, where
I can calculate all of the load and take the first 10kva at 100%
and the rest at 40%? Im thinking I can add all of the heat/ac units
and the water heaters together. With everything else in the house, (range
laundry, dishwasher, small app circuits & sq footage watts I come up with
120 Amps.
Now that being said, I'm thinking the house will be considered a motel, each bedroom
will be seperated from each other and have there own entrance. Then
I calculated the heating /AC units and the water heaters at 100%
That would put me at 243 Amps.
At any given time there could be six heaters going along with five water heaters and
someone using the oven, that would put it over the 200 amp mark.
I'm thinking of putting in a 300 Amp service to accomdate this load.
Can I get some input on this,
Thank You.
Sparky
120 Amps.
Thank You.
Sparky
