B
bthielen
Guest
This is not a code question but a design question I'm hoping someone can offer a possible solution.
As part of my home remodeling project, I had installed electric baseboard heaters throughout my home as part of a dual-fuel heating system. My goal was that the electric heating system would be my main system and my fuel-oil system would serve as a backup. Right now, because of the dual-fuel price incentives, it costs about 1/2 as much to use electric heat over my fuel-oil system.
The first heater I put in seemed to work just fine using heater mounted thermostats so I figured I would do this for all rooms rather than using wall mounted thermostats. This made wiring much easier and saved a few bucks, too. After all, this was a DIY project you know. These thermostats are nothing high-tech, just bi-metallic and there is no temperature setpoint reading or display.
Here?s the problem I have been having. I have the thermostats marked so I know where to set them to maintain about 68? F. in the room under most conditions. For some reason, I have found that the colder it gets outside the higher I need to set the thermostats on the heaters in order to maintain my desired setpoint. For example, this year has been unusually mild with the outside temperature consistently ranging from morning lows in the lower teens to highs in the mid-twenties.
This morning I awoke to -21? F. outside and my fuel-oil furnace was running. I have the thermostat for the oil furnace set at 65? F. as a backup. The electric heaters were not putting out heat so they didn?t believe the room was cold.
Some of these heaters and their thermostats are located on outside walls below windows (usually preferred) and some are not. I would expect those on outside walls to be more likely fooled into believing the house was colder than it really was, not the other way around.
I don?t seem to have any problem with temperature swing in the room once the outside temperature stabilizes so the thermostat hysteresis doesn?t seem to be a problem.
The only explanation I can come up with is that because the thermostats are mounted on the baseboard heaters, the heat radiating from the heater itself is interfering with the thermostats ability to sense actual room temperature and therefore is fooled into believing the room is warmer than it really is.
These heaters do have over-temperature sensors to protect against overheating but that does not appear to be the cause. All I have to do is turn up the thermostat and the heaters function fine so the sensors are not preventing the heaters from working.
Any other thoughts?
Thanks, Bob
Any other thoughts?
Thanks, Bob
