Fordean
- New Jersey
- Electrical Contractor
4,000 w is not even three hair dryers"cut states 2000/4000kw @208 1 phase"
Lota power there.............![]()
I think every one them in Holdredge and Minden.How many hair dryers does it take to draw 4000KW ?
A little, around 2000, My wife would scatter them all over the house so that the hairdryer is always at handHow many hair dryers does it take to draw 4000KW ?
2011 the site was probably designed to work on large screen what they have now was likely an attempt to make it work better on smaller screens?Grainger had a decent websight in 2011 which was then completely destroyed by IT personnel, who obviously know nothing about Technical Products or what works. The old websight actually was useful. This one is a colossal joke, and the product information and descriptions degrade on a daily basis. On this forum, its almost guaranteed you will have infinitely more expertise in determining what you are looking at in detail, than anyone else in their employ, and it may require going to other websights to get it all sorted out.
transformers. if you put two 2000 watt heaters in series would only get around believe its 500 watts of heat. I almost 100% sure that if you run a 2000 watt 240 volt heater on 120 volts you only get 25% of watts = 500. Won a lunch over this about 45 years ago against a know it all prima donna sparky. He still did not believe it even after using 3 different ampbrobes to meadure current flow.So half power merely eliminates one of two elements. I guess you could wire them in series if you wanted to.
No, Grainger's website's user interface has always been horrible. Looking for a lightbulb? Choose the lumen output desired: 780, 800, 805, 815, 818, 820, 830, "not specified", ... Choose one at a time and wait for a screen refresh after each selection. I can't choose a minimum/maximum range, like Newark's?2011 the site was probably designed to work on large screen what they have now was likely an attempt to make it work better on smaller screens?
Lots of sites like that, especially if they cover a wide range of product types and manufacturers like grainger does. Home Depot, Lowes and similar aren't much better, plus you need to use handyman and DIYNo, Grainger's website's user interface has always been horrible. Looking for a lightbulb? Choose the lumen output desired: 780, 800, 805, 815, 818, 820, 830, "not specified", ... Choose one at a time and wait for a screen refresh after each selection. I can't choose a minimum/maximum range, like Newark's?
Their back end -- inventory, shipping & billing -- seems to be flawless. (at least the results; I have no idea whether it's easy to use or horrible)
Some don't trust things like Watt's law or Ohm's law I guess.transformers. if you put two 2000 watt heaters in series would only get around believe its 500 watts of heat. I almost 100% sure that if you run a 2000 watt 240 volt heater on 120 volts you only get 25% of watts = 500. Won a lunch over this about 45 years ago against a know it all prima donna sparky. He still did not believe it even after using 3 different ampbrobes to meadure current flow.
A very large number. One of our compressor motors was 3.065MW.How many hair dryers does it take to draw 4000KW ?
