jmsbrush
- Central Florida
I have been doing some work in an older home, 70's I think. In the middle of the room there is a fire place. Its a back to back unit. So basically there are two fire places back to back. The brand is Heatilator and its called Zero clearance.
Now these fire places are surrounded by brick on the out side and has fire brick on the inside ,where the fire is. Then from there, It goes into metal ducts which go up and out through the roof.
I went in the attic and looked down at the ducts. I have a clearance from the brick to the metal duct down at the part where the fire would be about 6"
. Where it transitions in to the round duct I have well over a foot.
So here's the question. The home owner wants two receptacles on each side of the fire place. The sides where there is no Flew. She wants to put two small tables with lamps on them.
Can I drop 2 pieces of romex down and drill a hole in the brick and surface mount two Recept's?
I was told that there is not much heat down there because of the design being zero clearance and the fire brick. That basically the metal ducts and cover that you see when you are looking at it while you're in the attic is just bringing the smoke up and out.
Sorry for rambling. I'm in Florida,and not to many fire places.
