mkgrady
- Massachusetts
I have a customer that has had frozen pipes in her crawl space and I'm stumped on a good way to keep the pipes from freezing. She has the problem when the temps drop down near zero for any length of time. It doesn't happen that often. The plumber says the fix is not to use heat tape because some of the freezing is happening in the room walls above. The
Her house is all electric heat. She has a house with a full basement below the main house and a 4' tall crawl space where a 8' by 12' bathroom/laundry room addition was built years later. The water lines below the room run across the bottom of the floor joists. There is a board type insulation below the floor and pipes to separate the cold crawl space from the pipes and the room above.
The main basement is unusually cold and I would guess it's because there is no furnace or boiler down there. I guess the crawl space is even colder. There is a 3'x3' opening from the basement to the crawl space that was cut through the foundation wall to build the addition. My customer is a little old lady so I won't be telling her to go inside the crawl to do anything.
My first thought was to put a 30" strip of baseboard heat (500 watts) on the addition foundation wall closest to the pipes. IF that is a good idea, Im stumped on how to control the heater. I could install a thermostat on the baseboard buy I'm concerned it will never shut off. A line voltage wall thermostat would be impossible to reach without going into the crawl space, and again I'm concerned it will try to heat the whole basement. I would hate to have to tell he to turn the circuit on when it gets down near zero. I'm stumped.
