mbrooke
Batteries Included
- United States
- Technician
What is the total power rating when heating elements of different sizes are connected in series?
For example:
Element one is 3410 watts at 240 volts.
Element two is 2585 watts at 240 volts.
Ohms law says element one is 16.8915 ohms.
Similarly element two would be 22.2824 ohms.
22.2824 ohms + 16.8915 ohms = 39.1739 ohms.
At 240 volt 39 ohms gives 1470 watts.
However when one thinks about it the voltage drop is not even. Element two would have more volts and element one would have less volts meaning the current draw would in theory change based on the voltage. What does it stabilize to and why? What would be the wattage dissipated by each element.
For example:
