I don't believe that this applies to all dwellings.American Disability Act determinates heights for switches and wall receptacles.
The rockers just love it when we put our boxes at 48" to center. I try to be nice to them and go 48" to top, that way they're only carving up one piece and not two for every switch box. Recepts I normally go 18" to top. That's only if it's not spec'd out in the prints.Originally posted by sandsnow:
In CA it's Not ADA, it's in the CA version of the NEC.
The California Electrical Code 2004 version based on the 2002 NEC.
It only applies in multifamily dwellings where required. Usually a percentage of the total units and should be on the approved plans as to which units are required to in compliance. Ask you inspector.
48" max for switches and A/C controls and FA. No minimum
The center of receptacle outlets are min 15" AFF. Here you will get different interpretations. Measured to bottom recep on duplex or center screw.
