Help deciding on wire exiting sub-panel
jktaylor2020
New User
Tuscaloosa
Lineman
Hello all,
I need help deciding on what conductor to use.
Currently have a small-sub panel being fed by 10/3 w ground, from 30 amps 2-pole. When exiting the sub panel, what type/ size of wire should I use.
Outdoor pavilion(no inspection required)
Plan on using 3/4 EMT(already have some)
Load will be 4 can lights, one TV, two outdoor receptacles,
(possibly one cool vintage coke machine)
Thanks in advance. I am a distribution lineman for the local utility, this is not my normal operation.
.Thanks!
Per the forum rules we are unable to assist
with your question as we don’t know what else you are not asking. Try DIYchatroom.com
