renosteinke
- NE Arkansas
I once saw a Square D "QO" 100-amp main breaker that had melted and charred before failing. There was also damage to the buss where the breaker attached.
In that instance, it was simply the result of age- and pushing things to the max. The breaker routinely ran for hours at 105+ amps; it fed the dryers in a laundromat. When, a few years later, a Square D rep told me that their breakers were designed for only 80% loading, that they would instantly trip at the handle rating ... I could only smile.
So, I'd power up the heaters and see what they REALLY draw - you may find your answer there. Sure, the paint didn't help- but there might be an underlying issue. If the guy is pushing his equipment, he created his own problems.
