HELP..Ground/Neutral for MFG HOME
bradsguns
Cant find in my reference materials. When wiring a main meter/disconnect on electric co's pole for a 4 wire manufactured home system...Can the ground wire and neutral be attached to the same bar??? ... or does a separate grounding bar need to be installed ??
Thanks,
Brad
In So. MO, where we have no local codes.
Re: HELP..Ground/Neutral for MFG HOME
The ground and neutral are interconnected at the main disconnect, and not thereafter; thus the 4-wire configuration.
