Help Identifying GE Main Breaker?
jakequitts
Minnesota
Journeyman Electrician / Estimation
I ran into this GE Main 150 the other day that I need to replace for a house sale. I was wondering if anyone had any insights as to what the part number / breaker type would be. Most of the ones I'm finding have the thru lugs on the bottom but this one bolts directly to the busbar. Of course the cover is gone which has my breaker part number. The panel cover says replacement would be a TQD22150 however that brings up a thru lug breaker. Unless do you just remove the lugs and bolt it on? These breakers aren't cheap refurbed so thought I'd check here first.
Any ideas? Thanks!
You sure it's a GE Panel? I only see 4 GE breakers Most of the others look like Eaton and 3 SD HOM.
