I did a google search for carling c?3-??-2?-635-1?1-C
The part number decodes to various aspects of the circuit breaker, and some are less important for the application.
For example the '24' in the middle of the part number means that the unit works for 50/60Hz with a medium trip delay. 34 means that the unit will work for DC or 50/60Hz with a medium trip delay. So for this application 34 is as good as 24, and 22, 26, 32, 36 and a few others are probably 'close enough'
The 635 means 35A trip. Can some slop be accepted here, perhaps with an external breaker added?
The 2 in the 121 near the end means the actuator color. I presume irrelevant.
A bit of searching using the more general search term pulled up this in stock:
CA3-B0-34-640-121-C
It looks like the 40A version of the trip 34 breaker. This might be the closest version available off the shelf.
-Jon
