Help locating a fuse
tdjs
I'm trying to find a glass fuse 1x1/4" 6amp 230 volt that glows when it is blown.It has a intergrated light emmitting device in the fuse.The only markings on the old fuse has 230 volt stamp on it.This is used for a 120 volt control circuit.I know Littelfuse makes one for a 12 volt system called a smart glow.Any ideals who would have one for a 120 volt system?
There are adapters that let you use an ATC or ATO style fuse in an AGC type (round cylinder) fuse holder, but you would still be left with a smart-glow fuse designed only for 12 volts.
For a 120 volt circuit, I would have expected a neon rather than LED indicator. You may have better luck looking for a compatible indicating fuse holder instead of a fuse with integral indicator, like the ones shown here.
The reason that the indicators are more commonly part of the fuse holder is that when choosing a holder you know the circuit voltage while a fuse could be installed at any voltage up to its max rating.
