Im studying for my Oregon state test and i often have trouble finding some answers. Most i can find fairly quickly but usually some of them i can't find until ive spent 20 minutes searching for it.  So here are some that i can't find, or couldn't find quickly.  Basically i want to know how you found it, as in, what you looked up.  i really could care less what the answers are, i just want to work on speed
dwelling units shall contain at least ______ communication outlets
a. 1
b. 2
c. 3
d. 4
Buildings or structures supplied by multiple services or feeder must use the same
a. service
b. disconnect
c. electrode system
d. any of these
im guessing its electrode system, but i couldn't find it in the code.
each strap less than 2 in. wide containing one or more device shall count as a _____ volume allowance in accordance with table 314.16(b) based on the largest conductor connected to a device(s) or equipment supported by the strap.
a. single
b. double
c. triple
d. none of these
for ungrounded systems, non-current-carrying conductive materials enclosing electrical conductors or equipment, or forming part of such equipment, shall be connected together and to the supply system equipment in a manner that creates a low-impedance path for ground fault current that is capable of carrying_______.
a. the maximum branch circuit current
b at least twice the maximum ground fault current
c. the maximum fault current likely to be imposed on it.
d. the equivalent to the main service rating
a switch constructed so that it can be installed in device boxes or on box covers, or otherwise used in conjunction with wiring systems recongnized by the nec is called a ______switch
a. transfer
b. motor circuit
c. general use snap
d. bypass isolation
the material located in the nec annexes are part of the code and shall be complied with
a. true
a. false im assuming this is true, but is it in the code book?
where no statutory requirement exists, the authority having jurisdiction could be ta property owner or his /her agent, such as an architect or engineer
true
false
again, i don't care what the answer is, or even what the article is. I want to know how you found that article. What you looked up to find the article
a. 1
b. 2
c. 3
d. 4
a. service
b. disconnect
c. electrode system
d. any of these
a. single
b. double
c. triple
d. none of these
a. transfer
b. motor circuit
c. general use snap
d. bypass isolation
a. true
true
false
