fastline
- midwest usa
- Engineer
I am working to reduce both the torsional abuse and inrush current on a typical submersible pump motor. I am very much a fan of easier starting to protect equipment. I would normally want to reach for a 3 phase setup with a VFD but unfortunately with a 1HP pump, 3 phase is very uncommon, meaning even if i went that route, finding a replacement in a pinch would not be likely.
I have worked with hundreds of submersible pumps and know them well. I know that soft starts are becoming more and more common, however their design criteria is all over the map. The motor I want to test with is a common Franklin '2 wire' motor. This motor design does not use a start cap, but rather some electronics internally. I have a hunch it is a triac feeding a start winding but never got one apart because they are 100% potted.
Because I can find no one that has ever done this, my best course is to setup a test pump and monitor the start up carefully to evaluate. My target is to get inrush down to right at FLA. If the 2 wire until cannot be made to work, I may run further testing with a 3 wire, which does use a top side capacitor start. There are also some 2 wire capacitor start motors but those are literally junk as they submerse the capacitor attached to the motor and they 100% fail.
