Hi guys,
I am new to this forum, and I am DEFINITELY not an expert in this field. I'd like your insight on this.
I am trying to figure out how to do calculations when using a single phase load on a three phase panel.
If I have a 500kVA 208Y/120v transformer, how do I calculate the max single phase load? All loads are resistive and single phase. No motors or three phase loads anywhere.
I THINK that I should be able to use a full 500 kW in this case, but I'm not sure.
IF I wanted to use 120v, I think that I would be able to use 500k/120/3 = 1389 Amps per phase. In this case, since 120v is line to neutral, it would also be 1389 Amps per line, correct? That is, if I were take an ammeter and measure the current in any of the incoming lines at full load, would it also be 1389 Amps? If this is correct, then I would need an 1800 Amp main breaker on the box, right?
However, IF I wanted to use 208v for everything, then that would be 500k/208/3 = 801 Amps per phase. Is this correct? How would I calculate the current per line in this case (assuming everything was balanced)? That is, how would I calculate the expected ammeter reading on any of the incoming lines at full load? When I try to think about it, it gets confusing. If I'm using 208v, then all the breakers in the box will be 2-pole breakers on AB, BC, and CA. It seems like each phase should have a component of it's load on two different configurations, then. For instance, part of the load on line "A" comes from AB, and part comes from CA. If this is the case, how do you find the sum? I assume you need to add them vectorially somehow? (but HOW?)
If everything is balanced, my intuition says that it should still be 801 Amps per line. Would this mean that I would need a 1000 Amp main breaker?
Now, assuming the above is correct, in order to keep it up to code, I believe that I would need to go from the transformer into a distribution panel. From there, I could split the load into a few 200A or 400A panels and then go from there. Is this right? Even in this case, I think the math will be the same and simply proportional according to how I split it up.
