I am specifying meter stacks and the stack I will be using is rated 160 amp continuous model VMB-4. See this table:
The meter stacks with vertical bus's look like this, see page 27:
https://s3.amazonaws.com/dcc-data-extract/new-delta/asset/Compas/daily/Compas/Selection Application Guide/SIE_SA_POWERMOD_NYC_Metering_SelectionandApplicationGuide.pdf?10102022
There will be a 600A feeder under these stacks which feed the meter banks like this:
are we allowed to stack (4) 200 amp apartments in a single 160A continuous rated vertical bus? Is it dependent on NEC 220.84? How will we know if there will ever be continuous load of more than 160A if we don't know how long and how much each tenant will be running their equipment? Why is it rated at 160A continuous if we can put up to (4) 200A apartments in a single vertical bus? I would also like to mention that it is extremely difficult to find a continuous bus rating of more than 200A
