perrybucsdad
Thank goodness I found this place. I am a homeowner and I think the contractor is blowing smoke up my behind.
We had a house built and a monitored alarm (Burg & Fire) system was installed. Before we moved in we asked the contractor to install an outlet in the basement for us to plug a refigerator and freezer into. He had an electritian come out and put that outlet in. The problem is he installed a GFI outlet and took it off the circuit that the smoke alarms are powered off of. So everytime the freezer or refrigerator cycles on, it trips the alarm and the fire department is called.
I talked to the alarm company and they said that is not right and the builder needs to remedy the situation. The builder says it meets code.
What I am looking for is specific references to the code and their interpretation so I can go back to the contractor with specifics. If I'm wrong, I need to know too.
Thank you!!
John
Thank you!!
John
