TNGuy81
- Nashville TN
Im tring to help my neighbor out with his shop running a new circuit for a air compressor and I am not sure what to do. He wired this scary beast up back in 85 he said and I am amazed it had not burnt down. Its a 60amp sub panel fuse box run with 10awg for starters... 2nd. Its bonded and I know sub panels arent suppose to be bonded (not sure what to do.) Next the whip from the compressor is 10/3. From the receptacle to the fuse box is 10/2 with ground!! I jiggled the wire around just a little and it started arching. Apparently he is using the bare wire as a neutral. Then when I put the dead front back onto the panel I blew up a wire. A bare copper wire inside the panel had hit the dead front and it blew in half! Apparently it was never screwed on the entire time. He caught me off guard with out my meter or anything but Im going back in tomorrow to look again but I need some pro advice before I start. Also he is moving the compressor outside. Should I ground it with a grounding rod or to the frame of the shop or what? Thanks for any advise. I mainly do commercial and have never ran across this kinda application before. Thanks
