Re: Help on estimating whole (old) house re-wire
Wayne, it sounds like you are expert at using those bits. I need to learn from someone like you.
I've had a
little practice with mine, so I can offer the pessimism a pro like Wayne has long since outgrown.
I practiced when I first got one, by screwing a p-ring to the wall (in a rough), and trying to find the center of the header. (If you look up, it's cheating.) Wayne makes it sound easy, but it's not. Then, getting the bit to run straight up, without popping out of the wall overhead is a trick. I usually just buzz the corner of the wall and ceiling when I try, but I'm getting better.
The other things I've discovered:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Plumbing follows no logic.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">I carry an inspection mirror and a mini-maglite to see where I am, and if I'm about to drill a pipe.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Since I am so preoccupied with trying to not clip the corner, where I tend to mis-shoot, it's easy to lose track of where your drill is in relation to the outlet/switch hole you're using. Messing up a clean cut-in ready hole with the chuck of your drill is irritating.</font>
Words of wisdom from a flex-bit novice.
