I did some calculations for a some data center equipment and the Engineer that is reviewing it is questioning my calculations: We need to show the KVA per phase.
Here is the back ground, equipment is single phase 208vac, its 5640watts, total of 4 power supplies at 208vac each.
So:
Calculation #1 (myway)
5640 total watts / 208 = 27.11amps total draw
27.11 amps / 4 power supplies = 6.77 amps per power supply (208vac)
6.77amps / 2 = 3.38 amps per phase (120vac)
3.38 amps x 120vac = 405.6 watts / 1000 = .405KVA per phase
Or:
5640watts / 4 power supplies = 1410 watts per power supply
1410watts per power supply /208vac = 6.77 amps at 208vac per power supply
6.77 amps / 2 = 3.38 amps at 120vac per phase
3.38 amps x 120vac = 405.6watts / 1000 = .405kva per phase
Engineers way:
5640 total watts /4 power supplies = 1410 wattts per power supply
1410watts / 1000 = 1.410kva
1.410kva / 2 = .705kva per phase
Which is the correct way to do this? As you can see, my calculation vs his they do not match. Mine is .405kva per phase and his is .705kva per phase. What am I missing here?
So:
Or:
Engineers way:
