staticcontrol
Hello,
In a room on 3rd floor is a sub panel, 3 phase MLO. This panel is fed with #4 THHN/THWN from a disconnect on same floor in another room.
I want to take feeds off MLO and install a shunt trip breaker to re feed panel.
It's a 18 circuit 3 phase panel. It has (13) 20 amp breakers in it. Am I correct to select a 100 amp shunt trip breaker to back feed panel?
Any help is greatly appreciated. I also amp probed the feeds at the sub panel.
Black= 8 amps Red= 11 amps Blue= 6 amps This panel only serves some outlets in this room only.
Thank You.
Static
Thank You.
Static
