Hello everyone,
I have a 75hp, 3 phase, 480v, 85 FLA motor with 1.15 service factor fed via a 96 amp VFD connected to a 200 amp, 3 phase breaker on a 480/277v panel.
My question is what size breaker should be used on the panel to feed the VFD and motor? And also why?
I calculated breaker size is 300A assuming no VFD and using inverse time breaker. But what breaker size do we use with the VFD in between the motor and our circuit breaker?
Motor model: CEM2551T
VFD model: HMX09634NA
