I am having some problems getting my mind wrapped around magnetic induction: I am pretty sure I am making way to much out of it, but I sure would like somebody to set me strait. This what I think I have learned so far:
#1 whenever current flows through a conductor/coil, a magnetic field is created in the conductor.
The magnetic field strength can be changed in many ways. The amount of current flowing in the conductor will change the field strength... Or you can simply add more loops in the conductor to get more strength. Also, the polarity of the magnetic field is determined by the direction of the current flow.
#2 whenever a conductor passes through a magnetic field, a voltage is induced into the conductor. I guess this is what is called magnetic induction. The amount of voltage is determined by the strength of the field, speed of cutting action, or number of turns of wire.
Ok, so far I think I got it.
But now, I get messed up with the whole induced voltage/counter EMF or CEMF.
This is what I have got myself thinking and can?t shake. Break out the crayons!
Lets say you have a coil of wire.
You pass a magnet through the coil. As you pass the magnet through, you induce a voltage onto the conductors. This is one of the first basic laws. (Whenever a conductor cuts through magnetic lines of flux, a voltage is induced into the conductor) Ok, so now we have a voltage induced into the conductor. This is what I call the induced voltage. Correct? So now we have voltage or potential in the conductor. If we have a complete circuit, current will begin to flow. Ok, so now we have current flow, this current flow will create its very own magnetic field. This magnetic field will have an opposite polarity to the magnetic field that created the voltage that caused the current to flow. So, the two magnetic fields are opposite of each other, and the magnetic field caused by the induced current will want to pull the magnetic back into the coil. If we reverse the direction of the magnet, the polarity of the induced current will change and we will start all over again. I guess this is what is called Lenz?s law. This is how it is described in one of my books: The polarity of an induced emf will be such that any resulting current will have a magnetic field which opposes the original action that produced the induced current. Soooo, basically are they not just saying, that the two magnetic fields that have been created will oppose each other? The mag. Field creates a voltage that creates a current that creates its own mag. field. Right? What is getting me confused is what is the counter EMF?
This is what it says in Mike Holts exam prep book about induction.
When a magnetic field moves through a conductor, it causes the electrons in the conductor to move. The movement of electrons caused by electromagnetism is called induction. I guess he takes out the whole part of the induced voltage and goes right to just current flow. In an ac circuit, the current movement of the electrons increases and decreases with the rotation of the armature through the magnetic field. This is describing the induced voltage right? Conductors passing through a magnetic field create a voltage. The voltage is going to 0 to 180 on the positive sine wave and then going 180 to 360 on the negative. The degrees in which the conductors cut the flux lines make the voltage. This 0 voltage to 90 positive to 180 to 360 negative is what changes the current flow. He then says: As the current flowing through the conductor increases or decreases, it causes an expanding and collapsing electromagnetic field within the conductor. Yep, I get that, simple stuff. But this is where I get confused. He says: This varying electromagnetic field within the conductor causes the electrons in the conductor to move at 90 degrees to the flowing electrons within the conductor. The movement of electrons because of the conductor?s electromagnetic field is called self-induction. Self induction (induced voltage) is commonly called counter-electromotive force.
I just don?t understand. I understand everything right to there. Are we going all they way back through the entire process again?. If so, it makes me think of the nursery rhyme about the lady that swallowed the fly to catch the spider, and so on, and so on?It would seem that the varying electromagnetic field that is cutting the conductor would induce another voltage into it. .
In another book, it says, the induced voltage always opposes the original change in current. That is why the induced voltage is known as the counter-emf. Are we talking about two different voltages that get induced into the coil? The first that gets induced from the original magnetic that started the entire thing, and then the magnetic field from the induced current makes another induced voltage?? Man, I have really gotten myself confused. In Delmar?s book of electricity it shows a example of a coil and a magnet. It shows the coil with no induced voltage, the magnet is away from it. It says, if the magnet is moved toward the coil, magnetic lines of flux will begin to cut the conductors of the coil, and a current will be induced in the coil. Don?t I need the voltage first?? The induced current causes magnetic lines of flux to expand outward around the coil. As this expanding magnetic field cuts through the conductors of the coil a voltage is induced in the coil. Should there not be a voltage already in the coil?? Are they just simplifying the text or am I really missing something here? Anyhow, could you guys get me back on track? I am sure this is really simple but I have the rare ability to take something simple and turn it into something extremely difficult!
thanks
thanks
