I've been in the electrical field for about 12 years (low voltage/controls mostly) and finally doing the school required to get my electrical licence.
Here is what I am perplexing over:
If you have a electric heater that requires 10 amps to operate;
120v x 10amps= 1200 Watts
240v x 10amps= 2400 Watts
Electric meters outside the home bill you for kilo-Watt hours so wouldn't the 120volt be cheaper? Maybe I don't understand what the meter reads. Does it measure amps or does it measure Watts. My guess it is has be be reading amperes (the flow of electrons past a certain point in 1/sec) If it is measuring amps then it would make sence the 240volt would be cheaper to run because it would take 20amps @120v to get the same power (watts) as the 240volt.
Here are 3 questions were given to me to answer:
1. A 5-kW electric heating unit is connected to a 240v line. What is the current flow in the circuit?
my answer: 5-kW= 5,000 watts / 240v =20.833 Amps
2. If the voltage in question 1 is reduced to 120v, how much current would be needed to produce the same amount of power?
my answer: 5,000 watts / 120v = 41.666 Amps
3. Is it less expensive to operate the electric heating unit in question 1 on 240v or 120v?
my answer: I'm stumped because no where up to this point have we been taught how were are billed for the consumption of energy other than kilo-watt hours which I understand to be 1000 watts used in 1 hour. My answer to the question #3 is they cost the same because we have the 5,000 watt(5-kW) that does not change, all we are changing is the volts.
Thx in advance for the support.
Jerry
Jerry
