Well the Codes the Code...
The index is half the key, a word will not appear in the index unless it is used twice in Code Book. The Merriam-Webster Dictionary is your other related point of reference, as to a words defintion.
Both - Pulling from my Memory of previous posts posted.
U'd be well advised to soak in the
MH Web Site theres a lot of Free and informative "Stuff" here, and every one an always use some more "Stuff"...
Search or Advance Search, work's great here as well, use various term's, individual
Article numbers, or single term's, and U can usually find a close answer, note the title of the thread that's found from your individual query/word will usually be inside the located thread. In your case read the low count responses to you query, you'll fine your answer quicker.
Welcome Aboard!
