Help with 40 HP ELEVATOR SIZING
YoungMO
New User
St louis MO
Handiman
I have 2 -40 Hp traction elevators 460 volt what is the feeder size, the OCP (C/B), and what should the panel feeding them be rated at. Both controllers are at the top of the shaft in a penthouse. Sizing for emergency generator system.
Your profile says handyman.
Elevator electrical must be done by an experienced electrician, with permits and inspections. We don't allow DIY posts. If this is for an emergency generator thay may require engineering, the elevator loads and generator need to be coordinated.
