Hello, I have a Dryer and Roof Damper that needs to open/close together. Also I need to make sure the damper will not be left open at the end of the day after use. Will a time clock be a good idea? both are 120v.
I thought about sharing both load in the same circuit and running then through a time clock. The Dryer manufacturer does not included schematic for this, and also is not providing a terminal for the Roof damper operation, as it used to be the case years ago.
Thank you much
Thank you much
