Hi all, I need some help. I am a design engineer working on a tenant improvement project in the Denver, Colorado area.
My client is purchasing a NRTL listed/labeled piece of equipment. This piece of equipment happens to have a Square D loadcenter as a part of it. The Denver Building Code Amendments have a statement that "Panelboard circuit schedules including loads per each circuit, total bus load per phase, AIC rating and NEC demand calculations" are required on the electrical drawings. The Electrical Plan Reviewer is interpreting this to require a Colorado licensed engineer sign and stamp the loadcenter circuit schedules, and will not issue a building permit without.
I contacted the manufacturer, and they do not have an engineer licensed in the state of Colorado. They stated that they have never ran into this requirement before. I have designed the installation for over a hundred pieces of equipment from this manufacturer in the past in different locations and have never had a project be denied a building permit for something like this before.
My argument is that since this is a NRTL listed and labeled piece of equipment, this Denver Building Code Amendment requirement has no bearing on my electrical drawings for lighting and power design for the tenant improvement space.
Has anyone else ran into something like this? Any suggestions on a resolution?
Thanks in advance.
Thanks in advance.
