Help With Blood Electrolsis diagram please!
I'm having trouble finding much in the way of documentation on this suppressed device but was wondering if anyone could understand the instructions on it.
Here is the link: http://teslatech.com/beck/images/beck0103.gif
SPECIAL PARTS
B1: Filament type incandescent bulb, 6.3V 0.075A type 7377
(Ballast & current limiter)
Relay: 5V 50 ohm coil, PCB mount DPDT; Selecta Switch SR15P207D1
D3 & D4: Zener Diodes, 18V 1/2 watt NTE 5027A
R5: 100k ohm 1/2 watt linear potentiometer, Caltronics P-68 or equivalent
LED 1 & 2: combined as Bicolor red & green in same housing,
Radio Shack # 276-412
SW2: "Test" SPST momentary on subminiature push-button,
Radio Shack # 275-1571
Thanks for any advice, if interested in what it does let me know. :)
What does black helicopters have to do with creating a device that can pulse 50 to 100 micro amperes into nodes? Just asking for help with what the diagram means, its not a blueprint for a helicopter, if that is what you mean/
The diagram is apprently a 'Dr Bob Beck Blood Electrifier' :rolleyes:
http://www.life-enthusiast.com/company/recommended.htm
1) Use a blood electrifier to eliminate all viruses, parasites, fungi, bacteria and pathogens in blood.
2) Use a magnetic pulser to neutralize germinating, latent alien invaders and block re-infection. This quickens disease elimination, restores the immune system and supports detoxification.
3) Make your own colloidal silver to assist in eliminating all known pathogens and guard against opportunistic infections. Provide a "second immune system" while you are healing. Colloidal silver in normal doses has no known side effects, and has been found to be beneficial against many diseases. Plus, it will not create drug resistant strains.
4) This approach was only recently added to the other three. Use ozonized water for natural cell oxygenation without free radical damage, for universal detoxification by oxidation of wastes and dead and neutralized pathogens.
You can make these units yourself; information is provided. Or, you can purchase one. Hidden Cures manufacture a blood electrifier / colloidal silver combination unit.
Nevermind, its not available for purchase anymore...
"This unit is no longer available (but parts and service are available). This information is maintained for prior customers. As an alternative see:"
Back to squrae one in trying to build it.
The circuit is a device to separate a fool from its money, with the extremely unlikely possibility of removing said fool from the gene pool.
The relay is used as a simple DPDT mechanical inverter, producing square wave AC from DC. The timer circuit (7555 plus passives and transistor) cause the relay to pulse on and off and controlling the timing of the AC. The LEDs and zeners are there to produce pretty lights; the back to back zener diodes will always conduct, and thus do nothing. The resistors in this circuit are there to hopefully limit current.
Likely this circuit will do nothing other then deliver a mild shock. Positioned correctly, with very low resistance electrodes and the pot turned to minimum resistance, the 27V via the 1K resistor could deliver enough current to cause heart problems.
-Jon
I looked around that web site a little and found this little gem...
"Natural Law harmonizes diverse interests; to harmonize government's interest to protect society, and your right to know about and receive a cure, I provide information and links to information regarding the risks involved, and also put you under contract so that you waive your rights to the protection afforded by government.
Dr. Beck could be a quack, and blood electrification could be snake oil; you take the responsibility to determine this for yourself and not be a ward of the government, which in this case has already decided it is not for you."
winnie's first sentence said it all.......
