eclipse7120
Ok, I have an interesting project and need some help with the design. What I have is a shower building and 4 what are being called "treehouses" which are basically open air cabins on stilts. These are all seperate buildings on one site using the same electrical service. My idea is to use a 320amp meter socket which feeds both a 100 amp outdoor panel and a 225 enclosed breaker all mounted on a pedestal. The 225amp enclosed breaker will feed an electrical panel in the shower bulding ( I need this because there are large instantaneous electric water heaters) and the 100amp outdoor panel will feed the treehouses. My question is this, can I mount a panel in the shower building (it is basically one big bathroom, no seperate rooms) and does it have to be a main breaker since it is a seperate building even though it is being fed from the enclosed breaker? And also do I have to have a disconnect means at each treehouse even though they are being fed by only a single 20 amp circuit? Any help would be appreciated, thanks!
