Hi Mike
I hope all is well. I wonder if you could help me with a generator question.
I am installing a optional standby generator system. I am installing a 400
amp 277/480 volt main supplying a 400 amp automatic transfer switch. Which
in turn will be supplying a 400 amp distribution panel. My actual calculated
load will be around 150 amps. Can I install a generator capable of 200 amp
with a main breaker over current protection to supply my 400 amp transfer
switch ? Trying to interpret NEC article 702.4 B 2
Thank you
