Help with ground wire.
Cavie
SW Florida
Where can I purchase, in Florida, 30' of #6 solid insulated green copper?? I got a %^&)($ DOT spec requireing it for the EGC on a signal service. Gormans Plumbing carries #8 for the pool guys for some reason of which I don't know
infinity
New Jersey
Journeyman Electrician
Seems like the solid and insulated is the problem. Bare #6 solid is available everywhere.
roger
Fl
Green #6 is readily available here at a few supply houses, even in cut lengths.
Roger
Jim W in Tampa
Tampa Florida
Should be at least 1 supplier down there. Perhaps ask a pool company where they get it or see if #4 is available. Solid is the problem simply because they would not have large demand to carry it. Try big orange or blue
djd
djd
djd
I belive you can purchase solid 6 with a mc or bx type jacket, you can in cali, florida, be a little toough to insulate solid 6 with typical insulation. Enjoy.
