sfav8r
- San Francisco Bay Area
We are installing a 54Kw inverter that is for the sole purpose of eliminating short term peak demand. The system monitors the current flow at the main panel and when it senses a surge, it begins supplying power from the inverters until the surge is gone. This is very short term (minutes). The system is fed from a 100a breaker at the main panel. We install a 3 phase disconnect, then a new sub panel with three 30a 2-pole breakers (one for each of the inverters 3 18kw inverters for a total of 54kw). We have done a number of these installations in various jurisdictions and have never had a problem. We are currently in a jurisdiction that is requiring some changes that don't make sense to me. Essentially they want the wire, disconnects and panels rated for 200a, not 100a. Their position is that the panels is fed with 100a from the main panel breaker and 100a from the batteries (inverter) so it needs to be rated at 200a. We, as well as the manufacturer have explained that it is only one direction or the other, that the current cannot be flowing in to charge the batteries and out to feed the utility at the same time. They insist that that fact is irrelevant and want everything rated at 200a. they are citing 705.12 as a reference. It should be noted that this equipment CANNOT back feed to the utility. It only REDUCES the load temporarily. I cannot follow their logic at all. Even if we were to conceed that the new 3 phase panel would be rated at 200a (which it is anyway) who would the wire feeding the panel need to be rated at 200a if it is proteted with a 100 breaker. It simply doesn't make sense unless I'm really not understanding what the review engineer is saying.
This is a big issue because we have several more installs to do in this jurisdiction and some of the wire runs are quite long. The impact on installation cost would be significant.
Any help is appreciated.
And Merry Christmas to everyone!
