Long time lurker, first time poster. I've been helped by this forum so many times, I figured it was time to register. I am stumped by a wiring issue in a new addition a built. Installing a Lutron DVSCSTV dimmer as the first switch in a configuration. Both incoming power and lights connect to this switch. from this switch, I have 14/3 to a Lutron SC4PS-SW 4-way switch and then 14/3 from there to a Lutron SC3PS-SW. I'm following the below diagram. When done, the lights work at each location on/off, but if either of the 3/way or 4 way are off, the first switch will not turn the light back on. What am I missing?
I realize you are an engineer but we cannot help with DIY. I will say this, not all 4 ways will wire as your diagram shows. Usually the box has a diagram on it.
Please try diychatroom.com
This site is designed for:
Electrical Contractors
Electricians
Engineers
Inspectors
Instructors
Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
