busman
- Northern Virginia
- Master Electrician / Electrical Engineer
All,
For context, all the way back to my apprenticeship, I have never done New Construction I've done residential, commercial, industrial, even shipbuilding, but not that. So, construction on MY garage started yesterday. Below is from the plans for the wall section. Would you please confirm the following or tell me I'm clueless. I believe it should happen this way:
1) Footers get poured.
2) CMU walls get built (due the the height, the lower wall sections are CMU before going to lumber vs. lumber starting at grade.
3) At this point, I would think I drill hole for the conduit as shown below thru the CMU and mount the panel on the CMU wall.
4) Install CEE before slab gets poured.
5) Slab gets poured.
Also, was leaning towards GRC for the conduit (switch to PVC once outside the perimeter. Was thinking this since the panel is in one of the vehicle bays. Drawing shows recessed, but obviously surface mount due to the CMU construction (the CMU was a late change due to the height).
Thoughts? Recommendations? Tips?
As always, very grateful. Been waiting for this building for 12 years (long story). So excited.
Mark
Mark
