Help with race way
bajan
In B'dos there is a stipulstion of single cable in a raceway that was adopted from the NEC, where all circuits have to be identified by having each circuit seperated by using cable ties through out the raceway. Can you guys offer me some advice on this ruling here
Re: Help with race way
How are you to accomplish this?
If you are installing cable ties before you pull the wires into the raceway, that's a bad idea and I wouldn't reccommend it.
The cable ties can and probably will get stuck on every coupling edge and could possibly pull joints apart or even chafe the wires.
Or are you saying that where these wires exit the raceway you have to install wire ties on the circut conductors?
That is not an NEC requirement.
