BatmanisWatching1987
- NJ
- Jr. EE
I have a motor that will run continuous that has the following nameplate rating, see attachment for reference.
I also typed out the key information for your use too
EDrive Rating:
Voltage Configuration: 480V/3P
Power kW: 22
Max Input Current - Amp: 52
Max Output Current - Amp: 46
Motor Rating
Max Current - Amp: 38
Power -kW/HP: 22/29.5
Motor Operating Setting
Max Power - kW/HP: 20/27
Should I use the the Max Input Current of 52A.
So 1.25*52A = 65A
Convert to kW
65A*√3*480 = 54.015kW
Would I need a 75kW Transformer based on my calculation above.
Or can I use a 30kW Transformer since the nameplate says its uses only 22kW
EDrive Rating:
Power kW: 22
Motor Rating
So 1.25*52A = 65A
Convert to kW
